Implement Keywords based on body message
Juliano
I'm looking for a way to implement keywords inside the body message.
The algorithm will read the body message and add the keywords inside the same body message.
Read > Extract the keywords by using the RemoveStopWords Function > Write the keywords inside the message body.
Keywords: Sales, Invoice, etc.
I have one file containing some StopWords as mentioned, a function called RemoveStopWords.
Steps of my algorithm
1-Triggered by a custom button
2-Read the body message and store it in some variable
3-Read the file that has the StopWords ("C:\Users\Juliano\Documents\ListOfStopWords.txt")
4-Store the stopwords (step 3) in some variant variable
5-Remove the stopwords from the body message that are stored in some variable (step 2)
6-Store the Keywords in some variable (KeyWord as variant)
7- Update the variable that stored the body message (step 2) including the Keywords (step 6)
Public Function RemoveStopWords( _
       ByVal Phrase As String, _
       ByVal WordToRemove As String _
       ) As String
    Dim RetVal As String
    Dim Tmp As String
    'remove the word in the middle of the phrase
    RetVal = Replace(Phrase, " " & WordToRemove & " ", " ")
    'remove the word at the beginning
    Tmp = WordToRemove & " "
    If Left(RetVal, Len(Tmp)) = Tmp Then
        RetVal = Mid(RetVal, Len(Tmp) + 1)
    'remove the word at the end
    Tmp = " " & WordToRemove
    If Right(RetVal, Len(Tmp)) = Tmp Then
        RetVal = Left(RetVal, Len(RetVal) - Len(Tmp))
    RemoveStopWords = RetVal
End Function
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
I vba scrip to move emails based on long keywords list Outlook VBA and Custom Forms 0
I outlook rule keywords based on list Using Outlook 0
A Message Rules based on Keywords in the Message Body Using Outlook.com accounts in Outlook 1
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
geoffnoakes Outlook 2016 Searching based on CreationTime Using Outlook 3
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
K Conditional Formatting based on Department of person received from? Outlook VBA and Custom Forms 4
L Office 365 cloud based rules Using Outlook 1
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
M Move new mail to folder based on sender address Outlook VBA and Custom Forms 2
G Addition of 2 fields based on checkboc true or false Outlook VBA and Custom Forms 2
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
K Append subjectline based on number Using Outlook 4
D How to Run a Report Based on Age of Inbox Items Outlook VBA and Custom Forms 0
J Autoforward emails to different contacts based on certain criteria using only one rule Using Outlook 1
J Group email messages based upon information in InfoBar Using Outlook 0
D Delete previous email based on arrival of new email Outlook VBA and Custom Forms 1
S Send email from excel based on a condition (outlook 2007) Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
Tech Checkers Make Outlook add Contact Card Address in Location Field based on Appointment Subject Name. Using Outlook 2
V Outlook 2010 – Send email based on categories Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
H Rule to move emails based on subject and content Outlook VBA and Custom Forms 1
S Updating the database based on received task Outlook VBA and Custom Forms 3
L changing view settings based on message body Using Outlook 1
S Filtering based on mailing list field Using Outlook 1
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
