a general question re how backup programs handle pst files ... I have no problems, just curious
Dave Horne
Outlook 2019 64-bit
I have two pst files, one is 300MB and the other is 1.7GB.
I'm curious how backup programs handle these files when backing up.
If I make one small change to either file, the backup program 'sees' that the file has changed and needs to be backed up. With a file that is 1.7GB, does the backup program 'see' that file as ... one file? Does the backup program then back up a 1.7GB file or can is 'see' what has changed and just back up the difference?
I'm just curious what happens in the background, as it were.
Thanks, in advance, Dave Horne
D a general question regarding data files Using Outlook 3
F General Question Using Outlook 0
F 'General failure (URL) Server execution failed' Using Outlook 1
R Force use of general outbox Using Outlook 1
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
A Note field on general tab BCM (Business Contact Manager) 5
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
A Newb-ish question Using Outlook 2
A The hardest VBA/Outlook question yet Using Outlook 1
S DAG question Exchange Server Administration 0
P Outlook File Extension Question Using Outlook 3
J Outlook 2010 Calendaring Question Using Outlook 0
K Syncing outlook with iCloud question Using Outlook 5
T Outlook Prf/Automation question Using Outlook 2
T Settings question Using Outlook 6
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
IGWright Outlook 2013 .pst Question Using Outlook 10
F To Do Bar question Using Outlook 1
T I recently changed my pop3 email to an imap - question on folders Using Outlook 3
