Newbie question: how to sync two Outlook -Exchange and IMAP- calendars?
ofw62
Source is my Outlook 365 calendar (Exchange). Within Outlook there is a 2nd Outlook account (IMAP) and I want the contacts and calendar copied/synced from the 1st one.
I am not entirely sure how to proceed. Don't want to mess things up.
"My Calendars" looks like this. Ignore all the entries: they are .pst files of hardly used accounts or archive pst-files.
BTW - within "Shared Calendars" I have only 1 entry (USA). Q: how to get the holidays of other holidays in there?
on the holidays: assuming you want separate folders for each, you'll log into outlook on the web - open calendars then add calendar at the top. Choose holidays from the list and select the ones you want.
if you want all on your default calendar, add thenm in outlook's file > options > calendar > add holidays button.
on syncing with IMAP : IMAP does not have calendars and contact folders that sync with anything, not even the server. The contacts in the exchange box should be available to the IMAP account if it doesn't have 'this computer only' folders in it. if they are not, open the address book, click Tools > options and set it to show the contacts always
ofw62
Many thanks! The 'holiday' thing is solved, again thanks.
As for Calendars: I have a 365 subscription and within that a second Outlook account linked.
I am deeply... sorry, but I was confused myself and provided wrong information, sorry again, ahum... :oops:
This is the situation, share calendars from the default (1st) with the 3rd entry, also being on Exchange basis.
Does that make any difference?
Although it doesn't make much difference in Outlook desktop if you have both accounts in the profile, but you can share the calendars with the other account, from outlook.com. if you give edit permissions. If you remove one account from outlook desktop, you can edit the shared calendar in outlook if you enable the new calendar experience in File > Account Settings > Account Settings. Double click on the account, click More Settings > Advanced.
You cannot sync the events between the two, other than by using copy and paste or a macro.
ofw62
Am not sure ... in the 1st screenshot, the 3rd Outlook in that list is the 2nd one on Exchange basis.
Right now the default account is tagged only, of course, but what happens with the calendar in the 1st one if I tag the 2nd one ?
R Newbie get_CurrentItem() question Outlook VBA and Custom Forms 6
J Newbie confusion Using Outlook 0
E Newbie, desperately seeking help Using Outlook 2
S Seperating email accounts, Syncronizing, and a few newbie questions Using Outlook 5
C Newbie import issues Using Outlook 3
J Newbie needs help Outlook VBA and Custom Forms 2
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
Y Newbie : What is http://schemas.microsoft.com all about? Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
D a general question regarding data files Using Outlook 3
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
A Newb-ish question Using Outlook 2
A The hardest VBA/Outlook question yet Using Outlook 1
S DAG question Exchange Server Administration 0
P Outlook File Extension Question Using Outlook 3
J Outlook 2010 Calendaring Question Using Outlook 0
K Syncing outlook with iCloud question Using Outlook 5
T Outlook Prf/Automation question Using Outlook 2
T Settings question Using Outlook 6
