HTML to Plain Text Macro - Help
SamuelDawes
Good Morning,
I am using a macro that converts selected HTML emails into Plain Text, then prints them out. The macro works perfectly.
I was wondering how i would add some code that would format the selected HTML email to the 'No Spacing' style before converting it into Plain Text.
Condensing all the text from an email and removing all the guff, so it is in a format that prints efficiently.
Sub ConvertPlainText()
    Dim selItems            As Selection
    Dim myItem              As Object
    ' Set reference to the Selection.
    Set selItems = ActiveExplorer.Selection
    '  Loop through each item in the selection.
    For Each myItem In selItems
            myItem.BodyFormat = olFormatPlain
        'myItem.Save
        myItem.PrintOut
    Set selItems = Nothing
I have tried multiple solutions and exhausted my google options.
Any help would be much appreciated!
Kind Regards,
Sam
You would need to use the word object model to do that. I don't know if it would be easier to search for 2 line breaks and remove 1, after it is converted.
something like
mybody = replace(myItem.Body,vbcrlf & vbcrlf,vbcrlf)
myItem.Body = mybody
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
D Mail is received in Plain text even formatted and sent in HTML Outlook VBA and Custom Forms 1
M Plain text versus HTML email Outlook VBA and Custom Forms 1
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
M HTML email signature in Outlook Using Outlook 3
George Simpson "Switch to HTML" in Outlook 2016 notes field Using Outlook 1
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
S Outlook 2013 doesn't download html messages Using Outlook 0
cabinet guy permanent response in html Using Outlook 1
C Signatures in HTML emails Using Outlook 5
I Outlook 2013 Appointments not in HTML Using Outlook.com accounts in Outlook 2
B Replies never HTML Using Outlook 2
Diane Poremsky Outlook crashes when viewing HTML Messages Using Outlook 0
Diane Poremsky Create a New Message using an HTML File or Stationery Using Outlook 0
V incorrect html signature printed Using Outlook 2
Z alter the timeout for how long outlook looks for a content-server on an HTML-email? Using Outlook 5
Y HTML Emails Using Outlook 1
A Lync meeting in outlook lose HTML formatting Using Outlook 3
C Outllok 2010 (14.0.7015.1000 (32bit) converts html mail to rich text when move Using Outlook 1
T HTML email for internal mesages and Text only for External? Using Outlook 1
M Unable to read HTML Using Outlook 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
D Saving outlook emails in html and attachments Using Outlook 4
T Forcing HTML for replies in Outlook 2013 Using Outlook 4
M HTML mails apprearing broken in outlook 2013 Using Outlook 5
T Html tags in Message body Using Outlook 1
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
J Outlook is not parsing html email, unreadable and attachment not decoded Using Outlook 1
A Calendar to Web HTML - Multiple Files Using Outlook 1
S HTML Contents of an email Jumbled in Outlook 2010 Client Using Outlook 5
F "MSG" type attachments are stripped away when senand previewed with HTML tags. Using Outlook 3
C Save as HTML for multiple emails Using Outlook 1
G No word wrap in HTML email. Using Outlook 8
M Mail in HTML format can't be sent if url or number is in the body Outlook 2010 Using Outlook 2
