Outlook 2016 A Shortcut to recall and delete and sent message.
sev7en
Outlook 2016 64 bit
Good morning,
I am writing you as I'd like to know how it is possible to create a keyboard shortcut to recall and delete the last sent message.
Sometimes I am stuck to rush for the small icon where that function.
I guess just a keyboard shortcut can be very useful!
Cheers,
You can't add a keyboard shortcut - outlook doesn't support it - the default shortcut is Alt+HA1t (LOL - easier to remember than type - halt with a 1
Or add it to the quick access toolbar and its Alt+n where n is its position on the QAT
M Shortcut to another outlook item Using Outlook 0
R Shortcut for attaching the same file repeatedly Using Outlook 6
M Contact group shortcut Using Outlook 3
S Shortcut/button to a Calendar Group Using Outlook 0
B Can't create shortcut to Quickparts Using Outlook 3
iwshim word shortcut to search outlook Using Outlook 3
O Address Book Shortcut Using Outlook 4
S Desktop shortcut Using Outlook 1
Q shortcut to more stationery Using Outlook 4
A Shortcut for sending complete mail Using Outlook 1
I jump to body in open message with one keyboard shortcut? Using Outlook 3
T Column Header Keyboard Shortcut Available? Using Outlook 5
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
W keyboard shortcut to open Outlook... ? Using Outlook 2
S OL 2010 shortcut to edit received mail Using Outlook 3
L Shortcut to specific contact Using Outlook 4
C Want to Create Shortcut to Open Specific Calendars at the Same Time Using Outlook 2
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
F recall a message that is seen by HR Using Outlook 3
L Recall message feature Using Outlook 2
R Recall Email Message when i'm not the original sender - Outlook 2010 Using Outlook 2
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
O How to delete a forum post? Using Outlook 4
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 2
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
