Validating Outlook form with "OR" and "AND"
vincetaylor
Outlook 2016 64 bit
I need to validate an outlook form using an an "OR" statement.
When I validate without "OR", the formula below works. The form is not sent and the appropriate error message appears.
([Number] <>"1" )
But when I try to make it a compound validation by using "OR", the validation does not work.
([Number] <>"1" ) OR ([Number] <>"2" )
The form is sent and the appropriate validation message is not displayed.
I have tried to use the symbols "||" instead of "OR". That doesn't work at all. I get an Outlook generated error message that has nothing to do with the issue
My end goal is to use "OR" and "AND" in the same formula so I would also appreciate any help with "AND"
The end formula should look like this:
([Number] <>"1" ) OR ([Number] <>"2" ) AND [Letter] <> "A"
I would appreciate help with one or both issues.
R Validating a group of Checkboxes Outlook VBA and Custom Forms 2
M Validating Form testing 2 Conditions Outlook VBA and Custom Forms 5
hstein POP3 latest Outlook Using Outlook 0
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
F Moving Outlook to new PC Using Outlook 0
Ken Pascoe Outlook Categories Quick List Using Outlook 0
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 1
R Rogue Outlook Rule ? Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 8
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 12
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 5
S Mac Outlook 365 Questions Using Outlook 1
M Outlook calendar is missing Using Outlook 2
T Have you written an articles about Outlook? Using Outlook 3
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
R Outlook 365 update sets delete from server flag Using Outlook 1
X Outlook automation pull from PDF Using Outlook 6
O Outlook 365 - How to create / copy a new contact from an existing one? Using Outlook 3
M Gmail address associated with Outlook on new phone Using Outlook 9
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
