Trigger script without restaring outlook
Gazmoz17
Outlook 2016 64 bit
Discovered VBA a couple of months ago but only just come back to it. I'm sure when I started having a play with it originally...... I could trigger a script in this outlook session without having to exit and restart outlook. Im not sure if was a script itsself and that enabled me to do this. Something to do with outlook application startup...but I'm struggling to find any reference to it on any forum.
Many Thanks
Gareth
There are two ways to restart application start scripts - open VBA editor, click i the script and click Run. Or use a macro to trigger it.
I have this on a button in the ribbon to kickstart the Application_Startup macro when it seems to have failed. Put it in ThisOutlookSession.
Sub RunStart()
 Call Application_Startup
 MsgBox "App Start Started"
Gazmoz17
Outlook 2016 64 bit
That's great thanks Diane I knew it was a script that I got from you originally 👍😎
Gazmoz17
Outlook 2016 64 bit
I think I've misunderstood maybe as I'm getting an error?
put it at the bottom of thisoutlooksession module (the one with the blue outlook icon)
Gazmoz17
Outlook 2016 64 bit
Hi, thanks for reply. So I double clicked the thisoutlooksession . Entered the code to the right of it and ran & get the same error.
Or am I to right click and insert module?...but get the same error when I do this?
Apologies I know its a baby question and frustrating because Ive had it working in the past.
It goes at the end of the code in thisoutlooksession - well, or after the app startup - it doesn't have to be the very last macro.
C must select message to trigger safe list Using Outlook 3
T Sending One Email to Trigger Another Being Sent Using an Email within the 1st? Using Outlook 0
Z Trigger macro to run after a new mail is received in Outlook? Using Outlook 3
D Trigger macro to run when selected email is opened Using Outlook 3
R Trigger Application_ItemSend event when sending using Access macro Outlook VBA and Custom Forms 2
J dragging an calendar item to deleted folder does not trigger ItemRemove event Outlook VBA and Custom Forms 1
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
