VBA search string with special characters
Suji
Outlook 365 64 bit
I am new to the new forum and trying to help some help in importing emails from outlook into excel based on email body filter.
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
S VBA to search a keyword in attachment and move to a folder Outlook VBA and Custom Forms 0
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender Using Outlook 0
