Script does not exist
Gazmoz17
Outlook 2016 64 bit
I have used a script off the web to save attachments in my g drive and also print the attachment. Works great as a script rule.
I've tried to replicate this script copying into a diff module and renaming the sub, only difference is the folder path where I'm saving the attachment. Running it again as a script rule however, I get an error message script doesn't exist or is invalid.
I've deleted and re-inserted the module & renamed the sub to no avail. Tried removing the move to folder step in the rule before run a script step.
;Orig script
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias _
  "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
  ByVal lpFile As String, ByVal lpParameters As String, _
  ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
 Sub PrintAttachments(oMail As Outlook.MailItem)
  Dim colAtts As Outlook.Attachments
  Dim oAtt As Outlook.Attachment
  Dim sFile As String
  Dim sDirectory As String
  Dim sFileType As String
  sDirectory = "G:\My Drive\Outlook attachments\End of Day\Sage\"
  Set colAtts = oMail.Attachments
  If colAtts.Count Then
    For Each oAtt In colAtts
' This code looks at the last 4 characters in a filename
      sFileType = LCase$(Right$(oAtt.FileName, 4))
      Select Case sFileType
' Add additional file types below
      Case ".pdf", ".doc", "docx"
        sFile = sDirectory & oAtt.FileName
        oAtt.SaveAsFile sFile
        ShellExecute 0, "print", sFile, vbNullString, vbNullString, 0
Edited script:
 Sub Picko(oMail As Outlook.MailItem)
  Dim sFile As String
  sDirectory = "G:\My Drive\Outlook attachments\Picking Notes\"
Any help much appreciated.
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
