Place jpg in body of email
gaib
Outlook 2016 64 bit
I've added a line to this VBA code to add a jpg to the body of this email, but instead, it's added as an attachment. Can this be corrected?
Also, instead of having the contacts folder selected thru the PickFolder, can this be automatic where the VBA code selects the contacts container?
Public Sub SendDeferredBirthdayGreetings()
    Dim bday
    Dim objOL As Outlook.Application: Set objOL = Outlook.Application
    Dim objFolder As Outlook.MAPIFolder: Set objFolder = Session.PickFolder
    'Dim objFolder As Outlook.MAPIFolder: Set objFolder = objOL.ActiveExplorer.CurrentFolder
    Dim objItems As Outlook.Items: Set objItems = objFolder.Items
    Dim obj As Object
    Dim oContact As Object
    Dim TheYear As Long
    For Each obj In objItems
        If TypeName(obj) = "ContactItem" Then
        Set oContact = obj
        bday = DateSerial(Year(now), Month(oContact.Birthday), Day(oContact.Birthday))
            If Month(bday) = Month(Date) Then
                If oContact.Email1Address = "" Then GoTo nextrecord
                bday = bday + 0.25 ' sets it for 6 am the day of the birthday
                Dim objMsg As MailItem: Set objMsg = Application.CreateItem(olMailItem)
                objMsg.To = oContact.Email1Address
                objMsg.Subject = "Happy Birthday" & " (" & Format(bday, "mmmm dd, yyyy") & ")"
                objMsg.Attachments.Add "C:\Users\gailb\Desktop\Happy Birthday.jpg"
                objMsg.Body = "Dear " & oContact.FirstName & "," & vbCrLf & vbCrLf & _
                    "Dropping a not to wish you a Happy Birthday on your special day." & _
                    vbCrLf & vbCrLf & "Praying you have a great day today and the year ahead is full of an overflowing abundance of blessings." & _
                    vbCrLf & vbCrLf & "God Bless, Gail"
                objMsg.DeferredDeliveryTime = bday
                objMsg.Display
'                objMsg.Send
                Set objMsg = Nothing
nextrecord:
J Search and In-Place Archiving Using Outlook 0
piusg 2013: Place custom view on the ribbon Using Outlook 3
anoble1 Can you create a rule once an email moves to the Vault Inbox to another place? Using Outlook 0
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
P Select image in contact notes field and save as jpg Outlook VBA and Custom Forms 6
K Outlook 2007 preview jpg files Using Outlook 5
H Printing Tiff/JPG attachment Outlook VBA and Custom Forms 3
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
