Advanced e-Mail search on from/to contact group only searches for first 20 contacts in group
dogthebob
Outlook 365 64 bit
don't you organize your contacts in contact groups, too? And wouldn't you want to have an option to search for all emails sent to/from contacts in that list?
There is an option to do so in advanced search (I didn't find this in query builder or manual filter setup, only on first choice from/to selection) where one can select a contact group as from/to.
BUT unfortunately only the first 20 contacts in the contact group are considered. Is that configurable? Do you see any other option to search for emails from/to the persons in a group? I considered generating the search filter via VBA, too, but this approach was stopped due to the search string becoming to big for 20+ contacts.
Thx for any advice, Bob
O Advanced search - can I use booleans Using Outlook 3
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
Cathy Rhone Mail merge error message Using Outlook 0
R Sent emails show iCloud mail account not the alias Using Outlook 1
