Designer Form 2013 and Script ? how ?
WatLass
Outlook 2013 64 bit
I am trying to design a custom message (send email) form to make my repetetive task easier. (I want the message body and title to change based on custom field and attachment).
But I just can't get any script to run.
I created a new form with "Design a form" based on the standard message form.
I added a label, textbox and command button.
Then I clicked on "view code" and entered some basic script like (and Why is there no VBA editor, just like when you do a maro etc.).
Sub CommandButton1_Click()
msgbox "Hello World"
But I can't get that to work. When I "run this form", the display and buttons are there but nothing happens. Same when I publish the form to my personnal library. I just don,t know what else to do.
it's security changes... you need to set some registry keys. I have more info here -
J ol2021 custom form not displaying pics Outlook VBA and Custom Forms 28
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 3
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
V Validating Outlook form with "OR" and "AND" Outlook VBA and Custom Forms 1
V Form data not sending for some users Outlook VBA and Custom Forms 2
D Emailed form is blank Outlook VBA and Custom Forms 0
A Form Position with Dual Monitors Outlook VBA and Custom Forms 2
A Form style totally changes Outlook VBA and Custom Forms 2
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
