Forward incoming email with 4 embedded images in the body without original sender
fuz
Outlook 365 64 bit
I am trying to forward an email with 4 embedded images without original sender. The following script gets rid of the original sender, but the images are displaying as red X in the forwarded email. Direct forward set up as a rule displays the embedded images nicely, but with the original sender email. Is there a way to forward email with embedded images display and hide the original sender email at the same time?
Thank you for any help!
Sub SendTransfer(Item As Outlook.MailItem)
Dim objMsg As MailItem
objMsg.HTMLBody = Item.HTMLBody
objMsg.Display
objMsg.Subject = "Transfers" & Item.Subject
objMsg.Recipients.Add "xxx@xxxx"
objMsg.Send
Try using the word object model to copy and paste... not sure it will be any better though.
The macro at the bottom is for testing - select a message then run the macro - it beats sending test messages or running rules.
   ' Add reference to Word library
    ' in VBA Editor, Tools, References
    Dim objInsp As Inspector
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
If Not Item Is Nothing Then
   If Item.Class = olMail Then
       Set objInsp = Item.GetInspector
   With objSel
      'use wholestory to copy the entire message body
        .WholeStory
        .Copy
 Set objInsp = objMsg.GetInspector
 Set objSel = objDoc.Windows(1).Selection
With objMsg
    .Subject = "Transfers " & Item.Subject
     objSel.PasteAndFormat (wdFormatOriginalFormatting)
    .Display
    '.Send
Sub TestForwardMacro()
Set objApp = Application
SendTransfer objItem
fuz
Outlook 365 64 bit
Thank you for your response. The 'Dim objWord As Word.Application' was highlighted, and the following error message pop up. How to fix it?
Thank you,
fuz
fuz
Outlook 365 64 bit
I added the 16.0 word object library in the reference.
Oh sorry, I forgot to mention that you needed to reference the library. Did it do what you needed it to do?
Including images can be tough because they are attachments embedded in the HTML and just copying the body may not include them. If it doesn't work, removing the header block would be the next thing to try.
fuz
Outlook 365 64 bit
There was a box popup saying 'an unknown error' has occurred. The email didn't get forwarded.
It doesn't show you which line was the problem?
It works here when I select a message and run it (using the stub macro at the end). I didn't try it with a rule.
fuz
Outlook 365 64 bit
The VBA window did not open up, so I didn't see which line was highlighted. The popup box has one line: the name of the script and message -an unknown error has occurred. BTW, am I supposed to put the lines of macro in the script? I didn't
Thank you,
Fuz
This part is a separate macro, used to run the script on the selected message, so you don't need to send messages to test the rule.
Select a message and run this macro - do you get the same error? If yes and it doesn't show you were it stopped, you can step through the macro to see where it is dying.
fuz
Outlook 365 64 bit
Today the script does an unexpected thing. The incoming email arrives at 2 pm. At that time I happened to have some random sentences copied in my clip board. This script pasted the content what I had copied into the outgoing email and sent. (I ended up sending a strange email.) It seems the script didn't specify to copy the content in the incoming email that is specified by sender and subject within the rule prior to running the script. It sends whatever I copied at that moment instead. Please let me know your thoughts.
This is the script I am using
   With objSel
        .WholeStory
        .Copy
With objMsg
    .Recipients.Add "xxx@xxx"
    .Display
    .Send
Best guess: it failed on the copy and pasted the last thing copied to the clipboard.
If you copied at the same time as the macro, it would pick up what was copied last. If you had a message open and was actively working in it, it could pick that up.
I usually run the macro manually to copy messages to tasks or appointments.
fuz
Outlook 365 64 bit
So i should try not doing anything around the time (2 pm) to see if the rule that running the script would work?
if you expect the messages that match the rule come in at 2PM, yeah, pause and see what happens. Comment out .send so you can see if it screws up before it sends. If it uses the last copied item, the problem is the copy code.
fuz
Outlook 365 64 bit
Yes the problem is the copy code. It didn't copy anything from the content of the incoming email body.
ok... it works manually, but not automated. Back to the drawing board...
BTW - a quick fix might be to add item.display before the inspector - it will flash on the screen and be annoying...
item.display
<code to copy>
item.close <== can be early or after the message is sent
- to close it later - add it after the message is sent
With objMsg
.Display
.Send
item.close
fuz
Outlook 365 64 bit
Today I tested the following script and got a message. The VBA editor didn't open at all, so no code highlighted. I am going to test your suggestion tomorrow.
    Dim objMailDocument As Word.Document
    Dim objDocSelection As Word.Selection
    Dim objNewMail As Outlook.MailItem
    Dim objNewMailDocument As Word.Document
    Dim objInlineShape As Word.InlineShape
    Dim objShape As Word.Shape
    'Get the source email
    Select Case Outlook.Application.ActiveWindow.Class
           Case olInspector
                Set objMail = ActiveInspector.CurrentItem
           Case olExplorer
                Set objMail = ActiveExplorer.Selection.Item(1)
    'Copy the entire email to a new email
    Set objMailDocument = objMail.GetInspector.WordEditor
    Set objDocSelection = objMailDocument.Application.Selection
    objDocSelection.WholeStory
    objDocSelection.Copy
    Set objNewMail = Outlook.Application.CreateItem(olMailItem)
    objNewMail.Display
    Set objNewMailDocument = objNewMail.GetInspector.WordEditor
    objNewMailDocument.Application.Selection.PasteAndFormat (wdUseDestinationStylesRecovery)
    For Each objInlineShape In objNewMailDocument.InlineShapes
        objInlineShape.ConvertToShape
    'Clear the text in the new email
    With objNewMailDocument.Content.Find
         .ClearFormatting
         .Replacement.ClearFormatting
         .Text = "[^2-^255]{1,}"
         .Replacement.Text = ""
         .MatchWildcards = True
         .Execute Replace:=wdReplaceAll
    Do While objNewMailDocument.Shapes.Count > 0
       For Each objShape In objNewMailDocument.Shapes
           objShape.ConvertToInlineShape
    Loop
With objNewMail
    .Recipients.Add "xx@xxx"
    .Send
fuz
Outlook 365 64 bit
Your suggestion got the following error. Do you know how to fix it?
Thank you,
Fuz
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D Forward message to address from subject Outlook VBA and Custom Forms 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
W Macro to forward email Outlook VBA and Custom Forms 2
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
Diane Poremsky Forward Messages that were not Replied To Using Outlook 0
mikecox Forward email to another address; not with Rules Using Outlook 3
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
J Outlook 2010: can't forward appointment on custom form Using Outlook 1
J Forward a bounce mail? Using Outlook 1
