Need help with MS Authenticator
Donnat
Outlook 2019 64-bit
Outlook.com (as MS Exchange)
While this is not exactly an outlook issue, it does involve the office suite, security and logging on.
Just got an Iphone 13 yesterday. I use MS Authenticator on my iphone and ipad. I see the instructions for how to set up the new device using backup, however, the backup is from my Ipad. When I turn MS authenticator backup on my phone, it says backup already exists and do I want to overwrite it.
I know by design, the app is not synced across devices for security reasons. But then, I should be able to backup both devices to iCloud. I don’t understand how this should work – if the backups aren’t identical, then I should be able to have two!
Fortunately, I only have 2 authenticator accounts. So – should I manually recreate those two accounts (Azure and Microsoft) on my iPhone?
And if so, should I delete the app from old iPhone before setting up manually on new one? Or just set up new iPhone and delete old when I wipe it clean?
Or, should I backup Authenticator on iPhone – it will overwrite the ipad backup. Restore on new iphone. Then backup the ipad again and overwrite the iphone backup?
I just don’t want to mess it up and potentially lose access and I don’t understand why I can only have one back up - should allow a back up for the iPhone and a back up for the iPad. thanks.
You can't.... you can only have one backup (yes, it sucks). I have 2 iPad and an iPhone. I only back up the phone as I consider it my main device. If you aren't careful, you'll lose everything restoring the backups - BTDT - I reset the phone and the authenticator backup only brought back 1 account. Fortunately, I didn't need it to get into most of my accounts and set it back up - and the others had options for support to disable 2FA so I could get in and set it up.
I would not mess with the backups - especially with only 2 accounts. I would add the two accounts to the app.
FWIW, I like the Microsoft authenticator app but only use it for my main Microsoft accounts (on business and personal side) - for everything else, I switched to Authy as it can sync to multiple devices, including my desktop.
As silly as it seems to have 3 different auth apps, I might try the google authenticator again - I like tapping to approve, not typing in a code.. and Authy only does the code.
Donnat
Outlook 2019 64-bit
Thanks Diane. So I will manually add the two accounts to MS Authenticator on the new iPhone. Should I delete the accounts from the old iPhone first? Will it cause problems to have the same MS Authenticator accounts on two phones? I am going to wipe the old iPhone clean and trade it in, so everything willl eventually be deleted, but if I have to delete the accounts, I will.
No need to delete it from the other phone- and no, it won't make a difference. Both should work - handy if one phone isn't around. (assuming you are keeping it)
Donnat
Outlook 2019 64-bit
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Using Outlook 1
B Need help adding an image next to the Month Name in the header. Using Outlook 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
