Folder Pane Colour Categories
Sid
Outlook 365 64 bit
I was wondering if anyone has found a way to categorise the folder pane in outlook. I have lots of folders and it would be good to allocate colour.
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
B Outlook 365 - Folder pane list clears Using Outlook 28
R Folder pane width change Using Outlook 83
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
Diane Poremsky Outlook's Folder Navigation Pane Disappears Using Outlook 2
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
S Outlook 2013: Permanently Unhide Scroll Bar in Folder Pane? Using Outlook 7
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
M Folder View in Unread Mail Pane - Outlook 2003 Using Outlook 6
Y View Reading Pane for Drafts folder Using Outlook 2
B Search and Find Email by Folder Name Outlook VBA and Custom Forms 0
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 0
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
D How to remove a folder, option grayed out Using Outlook 4
D How To Combine Share Task Folders in just one Folder Using Outlook 0
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 2
B Spam folder not showing in Outlook Using Outlook 5
