Seeking help with Outlook rule
bhofmann
Outlook 365 64 bit
Using Outlook 365.
I'm wanting to set up a rule that triggers when I receive a message sent to an e-mail group I'm a member of, but only if that's the only reason I'm receiving the message. If the message was also sent to me directly, or to a different mail group I'm a member of in addition to the first group, I'd like the rule not to trigger. Is there a way to do this? I hope I'm being clear in what I'm trying to accomplish.
-Ben
So you want a 'if I'm the only recipient' but the "me" option won't work because the To address isn't your own address.
If the list of possible recipients will be limited, you could use a rule with exceptions- to the address, except if to the other address or to my address.
If that doesn't work, I have a macro that counts recipients.
bhofmann
Outlook 365 64 bit
Thanks for the reply! Based on your response I think I was able to get it at least close to what I want using exceptions. I will have a look at that macro though.
-Ben
E Newbie, desperately seeking help Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
S Dead computer-- desperately seeking address book Using Outlook 1
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! Using Outlook 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
