VBA for outlook to compare and sync between calendar
jackfood
Outlook 2016 64 bit
The laptop can either connect intranet or internet environment at one time. and using 2 different outlook profiles, shared with similar archive.
  1. main calendar are connected to intranet exchange (task will not appear when connected to internet)
  2. I have made an archive calendar and copy an exact duplicate from the main calendar.
  3. when connected to internet, I used software to sync those task to my Google calendar.
  • Issue - Everytime I am in intranet, I have to select all and copy the main calendar and it will form a duplicate events. (Not feasible to add one by one)
Any expert here can help on VBA that does the following,
  1. copy main calendar and paste into archive calendar &
  2. check for same events, if true, then skip.
  3. check extra events in archive calendar to main calendar, if true, then copy, else skip.
I don't know how difficult it will be, is it difficult?
jackfood
Outlook 2016 64 bit
or maybe
  1. Upon start up of outlook, copy main calendar and paste into archive calendar &
  2. check for new event from the main calendar, if there is, copy.
  3. check modified content with same heading & same time of creation from main calendar, if there is, replace/overwrite.
  4. check extra events in archive calendar to main calendar, if true, then copy, else skip.
This is my idea, i am open to any suggestion.
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
T Outlook AntiSpam with VBA Outlook VBA and Custom Forms 1
F "Move to" O365 feature to Outlook client via VBA Outlook VBA and Custom Forms 4
J VBA to switch Outlook online/offline Outlook VBA and Custom Forms 4
T VBA outlook, detect priority emails Outlook VBA and Custom Forms 5
S Outlook VBA Contacts Notes Outlook VBA and Custom Forms 0
O VBA or other solution for Outlook tasks to OneNote Outlook VBA and Custom Forms 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox Using Outlook 0
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
