Move or copy from field to field
Corsh
Hi , I`m new here and don`t know much about VBA so I have a question is it possible to move or copy category(only name without colours) from the default category field to another user made field i.e: category2, for all selected items (mails) in Outlook 2007 ??
Thank you for any help
JimR Copy or move contacts into BCM? BCM (Business Contact Manager) 1
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
N Move emails of same conversation to same subfolder Using Outlook 6
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
F "Move to" O365 feature to Outlook client via VBA Outlook VBA and Custom Forms 4
B Macro to manually move selected emails to network folder Outlook VBA and Custom Forms 1
L Making rule to move email to folder from one O365 domain Using Outlook 1
